click to hide/show revision 1
initial version
The lines of code you've shown there don't suggest you are removing all the Output:Variables. A simple way of achieving your goal could be to remove all output variables, and meters. This will mean you are not writing a lot of info inot the .eso. If the .eso is empty or close to it, the file size will be small. I'd suggest thats a lot quicker and easier than trying to persuade energyplus not to produce the .eso file.
