Hi @Anna
Did you verify that the field System Availability Schedule Name, Supply Fan Maximum Flow Rate and Supply Fan Minimum Flow Rate for all objects in the group HVACTemplate:System:VAV are modelled correctly? You would need to hardsize the max and min flowrates in these objects and apply the appropriate schedule in this object.
As per the I/O ref guide, Sizing:System is used for calculating system sizing for every design day in the IDF and the max heating & cooling air flow rates and capacities are saved for use in the component sizing calculations.
Hope that helps,
Raghu
Hi @Anna
Hope that helps,
Raghu
Did Once you run a model with HVACTemplate objects, it is a good idea to verify the inputs in the expidf to make sure that the field inputs in the HVACTemplate objects get translated as desired. System Availability Schedule Name, Supply Fan Maximum Flow Rate and Supply Fan Minimum Flow Rate for
I would suggest that you make a copy of the expidf and verify all objects in the group inputs related to flowrates of the following objects: HVACTemplate:System:VAV
DesignSpecification:OutdoorAir - just to make sure that the OA flowrates are modelled correctly? You accurately;
AirTerminal:SingleDuct:VAV:Reheat - I would need to hardsize used the option
FixedFlowRate for the field of Zone Minimum Air Flow Input Method and add the max and min flow rate in the respective fields;
Fan:VariableVolume - Use the option of FixedFlowRate for the field Fan Power Minimum FLow Rate Input Method and add the max and min flowrates;
Controller:OutdoorAir - verify the OA flowrates in these objects and apply the appropriate schedule in this object.
AirLoopHVAC - can be autosized.
