To load a library, please put it on the MODELICAPATH environment variable. Also note that the startup script changed recently in Dymola (I believe between 2017 FD01 and 2018) but you should not have to change this for BuildingsPy.
Does your script that has an unkown encoding use the same entries as buildingspy/examples/dymola/runSimulation.py?
