Couple of thoughts:
MeterCustom
because I guess you'd ideally want to create two to make sure you're monitoring the same stuff on both side, but if you could live with a small approximation or if you're sure you're monitoring source side energy, then use a MeterCustom:Decrement ![]() | 2 | No.2 Revision |
Couple of thoughts:
MeterCustom
