1 | initial version |
You need to provide a minimal workflow (OSW) file. Documentation is available here. It can be as simple as just identifying your OSM, a weather file, and your reporting Measure. Good for you for creating a Measure test!
2 | No.2 Revision |
You need to provide a minimal workflow (OSW) file. file since reporting Measures are tested in the context of simulation results. Documentation is available here. It can be as simple as just identifying your OSM, a weather file, and your reporting Measure. Good for you for creating a Measure test!
