1 | initial version |
The EnergyPlus mtd output file documents all of the meter connections. Assuming the OpenStudio bar chart is based on the ABUPS table output, then Interior Equipment is everything on the InteriorEquipment:Electricity, which is essentially all of the ElectricEquipment objects in the idf. Similar, for gas and other resources.
