Hi @Molly Curtz ,
You should be able model this supply air temperature reset based on the outside air temp using the object SetpointManager:OutdoorAirReset
EnergyPlus I/O ref guide has clear description as to how this object works and of each of the input fields. Did you try this already?
![]() | 2 | No.2 Revision |
Hi @Molly Curtz ,
