Once you import the IDF into OS, you need to assign each Space to an OS BuildingStory. Stories do not exist in the IDF data model, but they do in OS and SDD, so they need to be defined after import. There is a OS user script that helps do this, or you can select spaces and assign in the Inspector.C:\fakepath\OS Stories.PNG
