You should open your model in the OpenStudio application, it'll be easier to look at the thermostats on the thermal Zone tab. Make sure you assign both a cooling and a heating schedule, or the thermostat won't get forward translated to E+. If you don't need cooling, put a schedule with a very high value, like 40C or whatever.
Also, maybe you should upgrade your OpenStudio version to a newer one: https://github.com/NREL/Openstudio/releases
