Saving this way only saves the .skp model:
You need to saving using this button to save the .osm file:
Also, remember that if you draw something in SketchUp that is not a OpenStudio object (ie a floorplate that is made up of SketchUp surfaces) and then save the .osm and reopen it, the SketchUp only objects will not be there.
