Be great if you could paste your errors instead of using a picture in the future please!
Anyways, the reason why it fails to run is because you have surfaces that end up without a construction, one construction that doesn't appear to have any "Materials" assigned to it, and a a ZoneInfiltration:DesignFlowRate that is missing a schedule. All these should be easy to fix.
As far as your surface matching construction errors, open the model in sketchup and use the search tool to find both "Surface 388" and "Surface 377" and look at if they are correctly matched, and whether you have hard assigned constructions to them.
Anyways, the reason why it fails to run is because you have surfaces that end up without a construction, construction (I'd look at the default construction template you have set for your building...), one construction that doesn't appear to have any "Materials" assigned to it, and a a ZoneInfiltration:DesignFlowRate that is missing a schedule. All these should be easy to fix.
