I don't think this would work because OpenStudio's "reverse translation" (importing an IDF) does not work for HVAC objects so the resulting OSM would be incomplete.
I don't think this would work because OpenStudio's "reverse translation" (importing an IDF) does not work for HVAC objects so the resulting OSM would be incomplete. See the documentation.
Import and Export Options
I don't think this This would not work because OpenStudio's "reverse translation" (importing an IDF) does not work for HVAC objects so the resulting OSM would be incomplete. See the documentation.
| 4 | No.4 Revision |
This would not work because OpenStudio's "reverse translation" translator" (importing an IDF) does not work for HVAC objects so the resulting OSM would be incomplete. See the documentation.
