You can use an ZoneHVAC:IdealLoadsAirSystem for example, or the more convenient HVACTemplate:Zone:IdealLoadsAirSystem.
From the EMS Application guide for Ideal Loads Air System
An actuator called “Ideal Loads Air System” is available with control types called “Air Mass Flow Rate” (supply air), “Outdoor Air Mass Flow Rate,” “Air Temperature,” and “Air Humidity Ratio.
From the EMS Application guide for Ideal Loads Air System:
