From a quick look at the Small Office DOE prototype, seems it used an AirLoopHVAC:UnitaryHeatPump:AirToAir
with a Single Speed DX Cooling Coil, a Single Speed DX Heating Coil, and a gas supplemental heating coil.
In the OS Library, you won't find this exactly, the closest you have is one where the supplemental heating is electric, called "Unitary - DX Heat Pump - Cycling - Elec Reheat".
Couple of things to note:
You can then clone that into your specific model using the command line or a measure. Note that there no point trying to clone it into your own hvac_library.osm
currently as it would be there but you won't be able to select it in the OS App, that would require adding a new line to the source code (here)
