Unless your simulation model has a random number generator that is not initialized with the same seed in each run, GenOpt should give the same results if you do not make any change to the simulation model or the GenOpt files. There is nothing random in GenOpt, other than a random number generator in some algorithms, but this uses the same seed each time you start the optimization.
