After you run a simulation, there should be a X.rdd file, where "X" is the same as the name you saved for X.idf. In the IDF Editor, you should be able to add a new column for the Output:Variable object, and then use the drop-down list to select the appropriate variable you want to include in the X.csv output file (see below).
