Often if you have an unconditioned plenum space like a dropped ceiling, energy modelers just make it part of the space below, but it's fine to model the plenum as its own zone/space, and there are advantages to this approach at times.
Generally you model the plenum like other spaces but with the following exceptions
Now you're all set. As usual the plenum should be part of a thermal zone. You could make it a zone by itself, or combine it with the space below, but combining it with the space below defeats the point of modeling it separately, but is nice if you want to see how much of a difference it makes to the simulation results.
The approach for an attic is very similar, but you may have ventilation in addition to infiltration, and you may have insulation on the attic floor and no insulation on the attic roof/ceiling.
One last note. If you are modeling a very complex floor plan (50 +/- or more spaces) then plenum space may end up with more than 100 surfaces which can result in a slower simulation. One solution to this is to not intersect and match the attic with the spaces below but use an adiabatic boundary condition, but with that approach there would be no heat transfer across the plenum, may make more sense to do that when it is a supply or return air plenum.
