I don't understand what you mean by "...using a variable, T_com, and an input..." but if you like to have an hourly profile, it will be easiest to make a text file and read this file from CombiTimeTable, using the parameter tableOnFile and fileName. The model http://simulationresearch.lbl.gov/modelica/releases/latest/help/Buildings_Fluid_SolarCollectors_Validation.html#Buildings.Fluid.SolarCollectors.Validation.FlatPlate
uses such a construct.
