You could use python's threading module to make multiple calls to the CLI in parallel. (For ruby, the parallel gem would work nicely.)
You'll also need to specify a different run_directory (and maybe others?) in the OSW so that the runs don't try to use the same directory -- or simply put the OSWs in different directories.
You could use python's threading module to make multiple calls to the CLI in parallel. The subprocess module can be used for the actual call. (For ruby, the parallel gem coupled with a system call would work nicely.)
