click to hide/show revision 1
initial version
If you truly want a wall that does not participate in the zone heat transfer (does not store heat or conduct heat, does not radiate to other surfaces, etc.) then simply delete it from the model. Nothing will happen across that plane. But from your description of the overall model, it seems that what you really want is an adiabatic wall that will add thermal mass but not conduct to/from the outside of the zone.
