The results tab works all of the sudden. A Windows update appears to have fixed it. My computer has had some Windows updates and Flash updates in the last few weeks, but I am not sure exactly which one did the trick. The only recommendation I can provide to someone else having the same issue is to make sure Windows is up to date.
The results tab works all of the sudden. A My initial thought was that it was a Windows update appears to have fixed it. My computer has had some Windows updates and Flash updates in the last few weeks, update, but I am not sure exactly which one did the trick. The only recommendation it turns out, I can provide only access the results tab when I open the OpenStudio application through the Sketchup plugin. When I try to someone else having open the same issue is to make sure Windows is up to date.model directly in OpenStudio, the results tab does not work.
