If your Python code is memoryless, that is, the output of the Python code at time t only depends on the inputs at time t, then you could use the SystemCommand actor to call your Python script (http://simulationresearch.lbl.gov/bcvtb/releases/1.0.0/doc/manual/tit-CustomExeCon.xhtml) .
I will suggest following:
I suggest you studied few BCVTB examples such as the one which uses an EMS actuator as well as the one which uses the systemComamnd actor. Once you understand the two you will be able to connect the dots.
Note that instead of using the Simulator actor in the BCVTB, you could export EnergyPlus as an FMU, and import it in the BCVTB.
