You hit one of the rare model objects that changed from 1.x to 2.x. The 'Meter' object was changed to 'OutputMeter. I have updated the measure and will try to push i to BCL this afternoon, but it is pretty short, so if you want to you can replace the run method of your measure.rb with this.
#use the built-in error checking
if not runner.validateUserArguments(arguments(model), user_arguments)
return false
end
#assign the user inputs to variables
meter_name = runner.getStringArgumentValue("meter_name",user_arguments)
reporting_frequency = runner.getStringArgumentValue("reporting_frequency",user_arguments)
#check the user_name for reasonableness
if meter_name == ""
runner.registerError("No meter name was entered.")
return false
end
meters = model.getOutputMeters
#reporting initial condition of model
runner.registerInitialCondition("The model started with #{meters.size} meter objects.")
#flag to add meter
add_flag = true
# OpenStudio doesn't like two meters of the same name, even if they have different reporting frequencies.
meters.each do |meter|
if meter.name == meter_name
runner.registerWarning("A meter named #{meter_name} already exists. One will not be added to the model.")
if not meter.reportingFrequency == reporting_frequency
meter.setReportingFrequency(reporting_frequency)
runner.registerInfo("Changing reporting frequency of existing meter to #{reporting_frequency}.")
end
add_flag = false
end
end
if add_flag
meter = OpenStudio::Model::OutputMeter.new(model)
meter.setName(meter_name)
runner.registerInfo("Adding meter for #{meter.name} reporting #{reporting_frequency}")
end
#reporting final condition of model
runner.registerFinalCondition("The model finished with #{meters.size} meter objects.")
return true
You hit one of the rare model objects that changed from 1.x to 2.x. The 'Meter' object was changed to 'OutputMeter. '. I have updated the measure and will try to push i to BCL this afternoon, but it is pretty short, so if you want to you can replace the run method of your measure.rb with this.
return false
end
if meter_name == ""
return false
end
#flag to add meter
add_flag = true
end
add_flag = false
end
end
if add_flag
end
return true
