Repeating answer from helpdesk weather expert here. Read about the weather converter in the Auxiliary Programs document. With only Global Solar input, the program will automatically use the Perez model to split the global into direct and diffuse, which EnergyPlus needs.
You will need a "def" file that describes your input weather data. An example def file may be found here.
