OpenStudio 2.x introduced the OpenStudio Workflow (OSW). This is used by the OpenStudio application to run a single datapoint, and by PAT to run multiple datapoints (each datapoint has it's own in.osw file). It is not used by the "Apply Measure Now" dialog which applies a measure dynamically to your currently loaded model. An OSW identifies the seed model and EPW to be passed into a workflow, as well as the measures and measure arguments to be applied.
Before a simulation has been run you may find an file named "in.osw" or "data_point.osw", but after the simulation there should be an "out.osw" that is overloaded with additional information such as the info, warning, and error and messages.
You might be able to use this OSW file, which is structured as JSON, but there are some alternate options.
If you have more detailed questions about any of these three approaches, let me know. You get 1 for free, so I'd start with that and see if it works for what you need. I will point out that the out.osw can be long and harder to look through so you may want to look at the in.osw or data_point.osw first.
Before a simulation has been run you may find an file named "in.osw" or "data_point.osw", but after the simulation there should be an "out.osw" that is overloaded with additional information such as the info, warning, and error and messages.messages generated by the measure when it was run.
Before a simulation has been run you may find an file named "in.osw" or "data_point.osw", but after the simulation there should be an "out.osw" that is overloaded with additional information such as the info, warning, and error and messages generated by the measure when it was run.
| 4 | No.4 Revision |
| 5 | No.5 Revision |
| 6 | No.6 Revision |
