You might find it helpful to read the engineering reference on the coil bypass factor, here I can't link to the exact paragraph but if you search in your browser for "bypass" you will see the series of equations that are used to calculate the bypass factor. Since your cooling coil is autosized then I suggest that you scrutinize your inputs for the Sizing:Plant and Sizing:System.
