1 | initial version |
In general, the Construction object in EnergyPlus is a list of Material objects defined somewhere else in the IDF input file to represent the layers from outside to inside. The Construction:InternalSource object is similar, but one layer is an internal source of heating or cooling within the construction assembly (e.g. radiant floor with pipes throughout concrete). The severe error is saying that for the Construction object named "GBXML HEMCRETE - CBM1-0.075_0.07" has an internal heating or cooling source or sink, so it is specifically a Construction:InternalSource object. To fix the severe error, you have two options:
These settings will minimize the new layer's impact on the heat transfer and storage for the thermally active construction assembly.
