Are you using OpenStudio 2.x? If so, RunManager has been deprecated in lieu of the OpenStudio CLI. That test code would need to be rewritten.
Are If you are using OpenStudio 2.x? If so, 2.x then RunManager has been deprecated in lieu of the OpenStudio CLI. That test code would need to be rewritten.rewritten to call the CLI.
