Using surface intersection, either through the Surface Matching feature of the SketchUp plugin or the surface matching measure should slit the attic floor to match the spaces below. If you are creating a multi-story building, then you will also want to either assign an attic floor construction to the floor surfaces in the attic, or to a construction set assigned to the attic space. This will allow you to have unique attic floor constructions vs. typical floor constructions.
