click to hide/show revision 1
initial version
From the OpenStudio SketchUp plugin:
Extensions > OpenStudio User Scripts > Add or Alter Model Elements...
  1. Add New Thermal Zone For Spaces With No Thermal Zone
  2. Rename Thermal Zones Based on Space Names
...which will rename the zones as "Thermal Zone: Space Name".
If you want to change the zone name prefix you can alter the following code block from #2, which can be found here on a Windows machine:
C:\Program Files\OpenStudio 1.14.0\Ruby\openstudio\sketchup_plugin\user_scripts\Alter or Add Model Elements
  # rename thermal zone based on first space with prefix added e.g. ThermalZone 203
  if number_of_spaces > 0
    new_name = "TZ: " + spaces_in_thermal_zone[0] + multi
    thermal_zone.setName(new_name)
  else
    puts "#{thermal_zone.name.to_s} did not have any spaces, and will not be renamed."
  end
Where "TZ: " is the prefix. Zone names can be identical to space names, but might cause issues such as calling the getModelObjectByName method on a model.
click to hide/show revision 2
No.2 Revision
If you want to change the zone name prefix and are familiar with OpenStudio Measures you can alter the following code block the RB file from #2, which can be found here on a Windows machine:
Rename_ThermalZones_Based_On_Space_Names.rb
  else
  end
Other measures that may be useful:
