Modeling the multi-dimensional heat transfer into the ground from a building foundation can be very computationally intensive. The actual ground temperature varies significantly in three dimensions and depends on the climate, the foundation shape, and the level of insulation applied to the foundation. There are few whole-building energy simulation tools available that actually simulate multi-dimensional heat transfer into the ground.
Because the actual computation is so intensive, there have been several approaches to come up with simplified or pre-processed results. Of the tools available now, I think that the best approach (considering computation time and overall capability) is described pretty well in this DOE-2 article (the method can be applied to just about any simulation engine).
That said, there are several people working on improvements to estimating ground heat transfer:
With every numerical problem, there is a significant trade off between accuracy and computation time. I am not aware of a tool that strikes the right balance for typical building simulation analyses, but I'd like to think that we (as a community) are getting closer.
![]() | 2 | No.2 Revision |
