If you want to autosize, you'll have to add the WaterHeater:Sizing object as it looks like you've found. I'm not aware of a measure of BCL for this so you'll probably have to make your own. You can use this as a starting point. I wrote that one specifically for PeakDraw sizing. Hope that helps.
