Please see if the following Q&A addresses your question.
I believe that Q&A does address your issue. Judging from the error log you posted, I believe the space in your installation path is causing the problem.
I believe that Q&A does address your issue. Judging from the error log you posted, I believe the space in your installation path is causing the problem.problem. Try reinstalling to C:\OS2.1.1 and see if that fixes things.
