Starting with 1.5.4 OS uses EnergyPlus 8.2. This is more of a developer version, and unless you are comfortable with perhaps some bugs, I'd stick with the major versions (1.5.0). Version 1.6.0 should be coming very soon which will be compatible with 8.2.
With 1.5.0, you'll need to have EnergyPlus 8.1
