This is happening because the measure is not setup to run on space types that don't have any lights objects, as it uses existing light objects to create schedule for new lights object. We can update it in the future to be more robust, but for now if you put a lights object in the space type of the baseline model it should work fine. Make sure the light either has a schedule or inherits a schedule from a schedule set. We can update this to be more robust to add the light, but not attempt to set a schedule, if there was not a light in the space to start with.
