I was unable to execute some files in the GitHub repo folder as per (https://github.com/NREL/OpenStudio-BEopt/wiki/Development). 64-bit Ruby was successfully installed. On the Windows setup, I was able to get through steps 1-3. On Step 4 I ran into an error. I do not know which Gemfile I should be accessing. Should I be downloading a new Gemfile from here (https://github.com/NREL/OpenStudio/wiki/OpenStudio-Version-Compatibility-Matrix)? And replacing the existing one? Do I need download the new Gemfile and place it in the c:\RubyDevKit\ directory? How am I supposed to access the Gemfile? And then what do I no next?
Being unsuccessful at that, I attempted to run it in PAT using these instructions (http://nrel.github.io/OpenStudio-user-documentation/reference/parametric_analysis_tool_2/#create-a-project), and no luck. See attached photos indicating the order the measures were placed, and the "completed Fail" error I ran into on the Run-tab. I am unsure why it is not running. What follows is the order I placed the PAT files in, and the associated Run-tab error.
Suggestions?
![]() | 2 | No.2 Revision |
I tried both Ruby and PAT methods to no avail.
Suggestions?
