Those measures will be usable by the spreadsheet or (better) in PAT 2.x. We'll be refining the measures we currently use to calibrate models and adding some new ones (e.g. parameterized schedules) so that you can open up a canned project, add your seed model and consumption data, and go. The NREL Site Entrance Building example projects contain the starting point for those measure sets, ranges, and algorithm settings. They are equivalent to the old spreadsheet-based problems located here. We encourage new users to work in PAT, as it's much easier to make data entry errors in the old spreadsheets.
