LowTemperatureRadiant objects are zone equipment, and are a special case in OpenStudio in that the coils are shown on the demand side of the loop but are only really accessible from the Thermal Zones tab (under 'Zone Equipment').
Low Temp Radiant objects are available to add to a model from the Library pane of the Thermal Zones tab. Drag to your Zone Equipment spot:
To edit the equipment, select the instance and edit inputs in the right-hand 'Edit' pane:
