The OpenStudio results summary is still there. Perhaps you're looking at the EnergyPlus outputs summary instead? You can switch between them (and other customized reports) from the OpenStudio Application's results tab. PAT allows you to look at this reports for individual data points on its run tab.
The OpenStudio results summary is still there. available, but no longer runs "automagically" in version 2.x. Perhaps you're looking at the EnergyPlus outputs summary instead? You Add it to your workflow here:
Once it's added, you can switch between them the default EnergyPlus report (and other customized reports) reports you might add) from the OpenStudio Application's results tab. PAT allows you to look at this reports for individual data points on its run tab.tab, but you'll need to add them to your data points as a measure option.
