To run algorithms locally, you will need to setup your own OpenStudio Server. You have 2 options here: 1. checkout https://github.com/NREL/OpenStudio-server locally and build your own Docker containers. 2. use the already built docker containers and do the following:
docker pull nrel/openstudio-server:2.1.1 docker pull nrel/openstudio-rserve:2.1.1 docker pull mongo docker volume create --name osdata
Once the containers are spun up, use docker-compose with the .yml file located here
and then from that folder run docker-compose up
to add workers:
docker-compose scale worker=44
docker pull mongo
mongo
and then from that folder run run
docker-compose up
to add workers:
1. here:
2. containers.
docker pull mongo
Once the containers are spun up, use docker-compose with the .yml file located here and then from that folder run
docker-compose up
to add workers:
