If it can provide heating, then yes, if not then just model it as a packaged terminal device with a cooling coil and fan. If you're looking at OpenStudio default objects PTHP has a cooling and heating coil whereas PTAC just has a cooling coil. However, the default curves for the cooling coils are different in each of them.
