I've never tried setting up the server on a local machine, but from what I can see of the instructions, the Docker approach requires having an AWS account and VPC set up. Personally I like this approach better because you can make your machine huge to store all the results and you can spawn lots of workers (just remember to shut down the VM when you're done)
