Hello! I helped create the Measure. It should work, if you can edit the .idf before simulating. Can you do that? If so, change your ZoneInfiltration:DesignFlowRate object so that the schedule associated with the "infiltratation off" correlations is set to "always on". Then, set the schedule of the "infiltration on" correlations to be "always off". Make sense?
