As sub-optimal solution I imported the dwg into sketchup, used "add faces" to add all faces possible, this makes it a bit easier to see issues than in AutoCAD. I then fixed the most glaring and obvious problems. I then used "create spaces from diagram" and exported the resulting osm to gbxml. I then extracted all the floors along their "width" and "height" using a text editor and sorted the resulting areas to find the smallest surfaces. I then found the issues that caused these surfaces to be created and fixed them in the original dwg.
super fun.
