PTAC: Packaged Terminal Air Conditioning (Cooling Only)
PTHP: Packaged Terminal Heat Pump (Heating and Cooling)
Don't know why it's lower without looking at the inputs you're using.
PTAC: Packaged Terminal Air Conditioning Conditioner (Cooling Only)
PTAC: Packaged Terminal Air Conditioner (Cooling Only)
Don't know why it's lower without looking at the inputs you're using.using. You can compare the wrapped object inputs to see what's different between the two.
| 4 | No.4 Revision |
Don't know why it's lower without looking at the inputs you're using. You can compare the wrapped object inputs to see what's different between the two.
OS Default Curves for Coil:Cooling:DX:SingleSpeed in PTAC and PTHP
