The problem is that the Sky Diffuse Modeling Algorithm of ShadowCalculation model is changed automatically by EnergyPlus.
** Warning ** GetShadowingInput: The shading transmittance for shading devices changes throughout the year. Choose DetailedSkyDiffuseModeling in the ShadowCalculation object to remove this warning.
** ~~~ ** Simulation has been reset to use DetailedSkyDiffuseModeling. Simulation continues.
** ~~~ ** Better accuracy may be gained by setting the Calculation Frequency to 1 in the ShadowCalculation object.
This happens in SolarShading.cc#L675.
There is a Github Issue that seems relevant here.
I haven't found a way to shorten the runtime.
The problem is that the Sky Diffuse Modeling Algorithm of ShadowCalculation is changed automatically by EnergyPlus.
Shorten runtime?
I haven't found a way have set the Calculation Frequency to shorten the runtime.be 30 days (calc method set to AverageOverDaysInFrequency) instead of 7, runtime went down to 10 minutes.
| 4 | No.4 Revision |
Shorten runtime?
I have set the Calculation Frequency to be 30 days (calc method set to AverageOverDaysInFrequency) AverageOverDaysInFrequency) instead of 7, runtime went down to 10 minutes.
