I have had this issue before as well. From what I understand, OpenStudio counts on converting the EnergyPlus results from SI to IP. My guess is you are running the measure "Set Output Table to IP Units." If you delete that measure, the OpenStudio results should work.
There is a little more explanation from David Goldwasser here: https://unmethours.com/question/20371/openstudio-results-monthly-overview-demand-only/.
