1 | initial version |
Fireplace: Use ZoneHVAC:HighTemperatureRadiant
to model the fireplace, assuming it's gas fired.
Hot Water Radiators: Use a PlantLoop
with a Boiler:HotWater
which serves either ZoneHVAC:Baseboard:RadiantConvective:Water
or ZoneHVAC:Baseboad:Convective:Water
depending on your situation.
Not sure what your trying to do wrt '...attribute boiler heat losses to a single zone'. The Boiler:HotWater
assumes no losses to the space if that's what you're asking.
