I have seen this problem before. Both possible causes I can recall were related to the Controller:WaterCoil objects attached to the hot and chilled water coils. Not sure if either of these are the cause, but at least they're easy to test.
The minimum actuated flow was slightly above zero in the IDF because OpenStudio has a default of 0.0000001 (taken from E+) instead of zero.
The controller convergence tolerance was “Autosize,” which for some reason didn’t appear to be working.
