Here's how to use any of the getXXXXByName methods:
air_loop_name = "my air loop"
# This returns an optional air loop
air_loop = model.getAirLoopByName(air_loop_name)
# If you couldn't find it
if air_loop.empty?
puts "Couldn't match an AirLoopHVAC with the name #{air_loop_name}"
# Otherwise, get it (OptionalAirLoopHVAC > AirLoopHVAC)
else
air_loop = air_loop.get
end
Here's how to use any of the getXXXXByName methods:methods, which all return an OptionalXXXX object that you can call empty? (or is_initialized) on, and once you made sure it did find it, you can .get it:
if air_loop.empty?
else
end
Similarly, air_loop.name returns an OptionalString, meaning you need to call either .get or .to_s on it in order to get a String object.
For example, to list all the AirLoopHVAC names in your model:
model.getAirLoopHVACs.each do |loop|
puts loop.name.to_s
end
Here's how to use any of the getXXXXByName methods, which all return an OptionalXXXX object that you can call empty? (or is_initialized) on, and once you made sure it did find it, you can .get it:
if air_loop.empty?
else
// Do Stuff, eg:
puts air_loop.name.to_s
end
puts loop.name.to_s
end
